Gen 4 Side view mirror vibrations
All
just fixed mine:):):)
Its a simple thing, took me not even 5 minutes. The stealers wanted to replace the whole thing :?
Attached is the procedure to remove the mirror. What it doesnt tell you is be prepared cause it really pops out.... Lucky I managed to catch it.
The rattling comes from the "front or forward facing top cover" It has some clips on the inside (see clips pic) that I couldnt get loose. So, I glued it vas:):):)
Four spots of Pratley clear and pop the mirror back in. SORTED :mrgreen:
Also, a big thanks to the Ozzi guys for the destruction manual ;)
51.pdf
Instructions
(64.62 KiB) Downloaded 419 times
another clip also glued.
Clips now glued
Clips now glued
Re: Gen 4 Side view mirror vibrations
And silence is golden ;)
Now, all I need sorting is that blerry squeak when I go over bumps from the rear right suspension :oops:
Kai
Thanks for sharing this. Just a question. Did this fix a noisy rattle that you experienced? Or did it fix a wobbly mirror which makes it difficult to see in the rearview mirror? :?:
I am slightly confused as you make mention of vibration and rattle?
I have a wobbly mirror on the passenger side so will give it a go if it is the latter.
Christo
Nope, this was a vibrating cover on the mirror, which rattled :lol:
Will find the thread and post about fixing a wobbly mirror ;)
