was driving to work this morning whenthe instrument lights cut out. i have taken the instrument cluster out and all of the bulbs seem to bein good condition.
i also checke the fuse for the gauges andfound this does not affect the instrument lights, just the gauges themselves.
so i was wondering if there is another fuse for these lights and where it is ?
or if anyone has had this problem before
cheers
more than likely the dimmer adjuster switch.
I played around with the dimmer switch but it does not make a difference to the lights
My D light had blown. How did you get the instrument cluster out? There are 2 screws at the top, but what holds it down? I cannot get my fingers in under the cluter after removing the panel which covers the bottom.
Eugene: mainstreetprop@mweb.co.za
