My side rear mirrors does not operate electrically anymore and I tried to look for a blown fuze, but cannot find a fuze that operates the rear view mirrors. Does anyone know what can be wrong? I looked in the manual, but cannot find anything.
Second question, how do I open the side mirrors to look inside, the lefthand one is loose and vibrates if I am driving, so something is loose inside the housing that holds the mirror.
Wilfred
Can't help on the first question, but might have an idea on the second. If it only vibrates you might be able to tighten a screw through a small hole on the underside of the mirror. Apparently some models have this feature, not sure if yours does. If it is more than a vibration I agree that you might need to open it, but I have no idea how
On the mirror not working, maybe the plug that connects it to the door worked looses in some way?
