No. My 2001 Di-D GLS came standard from the factory with low oil level sensor. Maybe because they knew how prone the oil pressure switch was to failure (when it fails it spews oil and also doesn't allow it to trip the low oil pressure lightpierreandre wrote:Did you install aftermarket sensosrs?4ePikanini wrote: would much rather spend the money on a coolant loss alarm (my pajero has oil pressure sensors and low oil alarm so I'm redundantly covered there)
https://www.pajeroclub.co.za/forum/view ... =55&t=1856
