Transkeicowboy
EGT probe position
Can someone who has fitted an EGT system to their 3.2 Di-D please post a pic of where they fitted the probe to? I want to fit mine but would appreciate some assistance with this.
Thanks.
Re: EGT probe position
Have look here https://www.pajeroclub.co.za/forum/view ... robe#p6725
EGT was discussed and there is a picture courtesy of 4ePikanini
__________________
JohanV wrote:Have look here https://www.pajeroclub.co.za/forum/view ... robe#p6725
4epajero's EGT gauge.
th closer to the head the better
macjohnw
Does one simply drill a hole, tap it, insert the probe, run the wire through to your dashboard and connect the display unit to power?
macjohnw wrote:Does one simply drill a hole, tap it, insert the probe, run the wire through to your dashboard and connect the display unit to power?
In a nutshell, yes. Be carefull who you allow to drill and weld a bung. Do it wrong and you will crack a very expensive exhaust manifold.
macjohnw
Thanks, think I would rather have some experienced oke do it for me then.
Here is my installation.
MGL TC1
MGL TC1
MGL Avionics.jpg (4.7 KiB) Viewed 2586 times
If I have to do it again, I would do it differently.
Why?
  • the probe in it's current position registers an average EGT for the four cylinders (which is fine for
    • pump tuning,
    • air cleaner element condition
    • driving style
    • etc.
  • it is however highly unlikely to pick up over-fuelling on one cylinder! (which I have now realised is the most likely fatal failure).
My suggestion:
  • MGL 4-channel guage
  • 4 x Type K probes,
  • each fitted as close to the head on the outlet ports of the 4 cylinders on the manifold
macjohnw
4ePajero wrote:Here is my installation.
Why?
    • pump tuning,
    • driving style
    • etc.
My suggestion:
4e, what would a setup like yours with 4 probes cost then?
I agree with 4E regarding the 4 probes as it would probably give a better indication per cylinder.
I have had mine done the cheap and nasty way, but I am still happy with the results. Definately not as neat as 4E's one and obviously not as accurate, but still effective as far as I can tell. But a lot easier to install as the hole was drilled and tapped on the EGR section of the manifold which is not covered by anything that had to be removed.
macjohnw wrote:4e, what would a setup like yours with 4 probes cost then?
I bought my stuff many moons ago.
Get a quote from http://www.mglavionics.co.za/ for the hardware.
The labour is cheap (DIY)
