Hi Everyone
I did a 4x4 Drivers and Recovery course over the past weekend. Unfortunately we couldn't do a demo snatch as (according to the course leader) the standard factory fitted rear recovery point on my 1997 3.5 V6 LWB had been removed to fit a Hayman Reese towbar (with removable hitch) and this could not be used snatch. It stands to reason that I would want to refit the rear recovery point as we are planning a Botswana trip in June 2011.
Can anyone pse confirm that the Gen 2 is normally fitted with a rear recovery point and maybe load me a photo to see what it looks like and where exactly it is fitted? And I suppose the best place to source it would be from a Pajero that is being stripped somewhere?
Elbgeo,elbgeo wrote:Hi Everyone
I am unaware of standard rear recovery point on the Gen 2.
Look here: Nino62's Hook at what one member did (also see the further comments and suggestions). Personally I would go for a ring, rather than a hook, but I think the hook will work well - especially if further reinforced as suggested by another member.
The Gen 2 did indeed come with a recovery hook bolted on with the 4 bolts where the towbar comes. It was just a "flat plate" with a loop on it. I worked at a Pajero dealership back in the 90's, we always had to take off the recovery hook in order to fit the towbar.
Hope this helped
Jaco
Hope this helped
Jaco
Nothing wrong with one of these.. I have done countless recoveries (and been recovered
) with this..
