- Remember to clearly mark vacuum pipes in order
- IMG_1671.jpg (23.21 KiB) Viewed 943 times
- Normally 5x bolts holding the housing in place (4x in front & 1x on side bracket)
- IMG_1673.jpg (23.05 KiB) Viewed 943 times
- What the throttle body should look like, after thorough clean-out (including rear inlet housing) & no play on butterfly shaft
- IMG_1675.jpg (22.8 KiB) Viewed 943 times
- IMG_1724.jpg (22.95 KiB) Viewed 943 times
Achille
