Freshman
Horn relay
My hooter stopped working.
Checked the steering switch (bypassed to earth) and also checked the fuse.
Is there a relay maybe? (nothing in manual).
Site Admin
Re: Horn relay
Freshman wrote:Hi,
You might find there is a problem with the contacts in the stereing wheel itself. Pull the plastic cover off and check that the contacts behind the horn press are making good contact
Freshman
Re: Horn relay
it turned out to be the relay that got wet and the contacts rusted so I cleaned them up and re-sealed the relay.
Thanks for the diagram showing the location else I would still be searching for the relay under the dash somewhere...
