offtrac
Warn Spotlights
This I am sure is a topic that has come around before, but I have searched for it and found nothing.
My question is that I want to fit two warn Spots on the front Metal bumper section and want to know if it will affect significant airflow to the radiator and condenser panel that I should leave them off. I see quite a few Pajero's with them on the front bull bars. Mine is the v6 3.5. Thanks for any advise.
Dave
offtrac.com
ghost_traffic
Re: Warn Spotlights
I had a set of Warn spots mounted in the exact same place as you mentioned without any hassles.
I have since fitted an ARB bumper/bullbar which have mounting points in the same position, so I suggest you go for it and mount your spots. :D
Nico.
tonton
Re: Warn Spotlights
Dave,
Check my avatar - I have fitted mine straight onto the bumper (it already has the factory-punched holes in the steel under the plastic of the bumper), and can assure you - there is no difference in efficiency of airflow through the radiator.
I am sure thay are designed to have the possible distortion caused by bullbars and lights.
