Dave046
HELP !! - Dashboard lights - ABS and ESP
Hi, I am having a problem with my Pajero DID SWB 2004, My ABS, and both ESP lights on the left hand side of my dash are staying on.
I spoke to the service manager at Pajero, and he reckons I check the fuses in my fusebox, as from towing I may have popped one, I checked and all is in order.
Has anybody come across the same problem..?, rather than send in and incurr some horrible diagnostic costs, I would rather try myself if possible.
There may be a loose plug behind dash, but I doubt it..........
Please help if possible, or perhaps if you've encountered the same problem.
I have tried to "test" to see if the system is still functioning, even if the lights are on, but dont particularly want to wipe myself out in the process..
Help,
Dave
redvers
Re: HELP !! - Dashboard lights - ABS and ESP
Hi Dave
I had the same problem when towing my caravan and the taillights blew my fuse and caused the lights to come on. look at the fuse box next to the battery. Test the fuse as I have seen fuses that appear ok, but have actually blowm
Hope this helps
Dave046
Redvers, thanx a ton, will re-check and disect the little buggers.
I'll post my findings, once again....thanx
Dave046
Fixed....!!!, thanks a lot...saved me a service call......When I actually put the fuse up to light it had popped on one of the"legs".
Champion, thanks for the help...!
redvers
Hi Dave
Glad that you sorted it out
tonton
WOW, we learn every day...
hi you guys - i am getting addicted to a pajero and this site - must say i have a problem on my gen 3 dash - the r/h light of my 4 wheel drive indicator - in 2H does not "show" - any advice will be highly appreciated?
regards
deonengel
Sound advice, if you want to enter in a BBBEE business venture? Think twice! Make sure your i's are dotted and t's are crossed :ugeek:
deonengel wrote:hi you guys - i am getting addicted to a pajero and this site - must say i have a problem on my gen 3 dash - the r/h light of my 4 wheel drive indicator - in 2H does not "show" - any advice will be highly appreciated?
regards
deonengel
Just a blown globe.
hallo marius - nope - het reeds cluster uitgehaal - 4 nuwe globes 'gefit' - sal maar met probe moet toets - miskien by die 'pug' agter? - dankie vir jou 'trugvoer
RoelfleRoux
Just an observation with regards the original post.
I have on a few occasions come across Dave's problem.
The three things that always seem to go hand in hand are the following:
1)Sometimes after sticking something into the trailer light socket,
2)Something, somewhere on the dash display goes dead and
3)The first check of fuses fail to show a blown fuse, but a follow-up detailed inspection finds the blown fuse.
The conclusion I draw form this is that the Pajero is wired in a such a way that visible objects, from the driving position, are linked to the various fuses that protect the wiring to the external lights. That way you will always know if a fuse has failed to any of the external lights.
