Chris wrote:Karl, the Ctek DC2DC that I have only kicks in at a constant voltage of 13,4V for approx 30 sec's. It cuts out at something like 12,4V IIRC. It will therefore not drain your main battery.
Chris
DC-DC chargers are not similar or identical!
I checked the CTek's spec, as listed on Bushpower's Website.
It does in fact state that it will only connect at
"from 13.4V for 5 seconds",
and disconnect at
"below 12.8V for 10 seconds"
__________________________________________________
Compare that to the BC Series DC-DC charger:
Input: 10-15V
Cut-out when input voltage is outside these two figures.
Another alternative is the Waeco:
MHO:
- The Ctek DC-DC:
- This is obviously aimed at being used with an alternator as the input source.
- The cut-off values make it impractical to use with other "12V" sources.
- The low cut-off makes it risky to run 'thin' cables/wires to the back of your vehicle - the voltage drop might just be enough to prevent it from connect. THIS DEFEATS THE OBJECT OF DC-DC CHARGING!
- The intelligent charging is a benefit.
- BC Series:
- This unit has intelligent charging.
- The low and high cut-off values for the input source means that it can be used as an effective, intelligent charger, using ANY '12V' source, such as
- alternator,
- other batteries,
- 'dodgy', cheap battery chargers,
- cheap AC-DC converters
- WAECO:
- NO intelligent charging.
- The low and high cut-off values for the input source means that it can be used as an effective, but NON-INTELLIGENT charger, using ANY '12V' source, such as
- alternator,
- other batteries,
- Provides a constant 14.2V output, with up to 40A current.
- Acts like an alternator!
My choice?
The BC series, for the fact that it can use 'dodgy' input sources to provide intelligent charging.
- Choose according to your needs!
- If used in parallel with other batteries, cut-out can be controlled by diodes (non-return valves
), solenoids or low-voltage cutouts (such as fridge protectors)
Reason: Bloody nested lists! :)
