The way I see it:
- You have a battery to charge.
- You chose to charge it with a DC-DC charger, which claims it can use min. 10.5V input voltage.
- The input (charging source can be one of at least the following sources:
- The alternator
- A solar panel
- Another (charged) battery
- In the case of using the alternator, you have to protect the cranking battery from running flat (because it is coupled to the alternator)
- In the case of using another battery as charging source, you have to protect the charging battery from being depleted below a chosen voltage
