dr3am3r
What model / year is your Pajero? 1995 gen2 2.8 SWB Japan import auto
How much mileage had your Pajero done? 198 000 but the clock is dead, so im thinking it has a whole lot more. (still searching for a speedo sensor)
Is it the original motor? I believe so
Any major work? Reconditioned the fuel pump and injectors, still drinks a lot, had a diesel leak on the pump. changed some poly bushes on the rear suspension. she still drinking a bit. changed the gaskets on the manifold. did a general service (all fluids and filters minus gearbox oil)
Things to be done: Got flashing green lights, noisy when engage 4wd, mech says the boot, bushes are torn and need a new "cardan" (dont know if thats the name in english). need to do the timming chain job (according to him its a chain not belt driven engine)
saving up to take her to the stealers in nelspruit or drive the 600km and go to Mitspro.
In the coming weeks ill be doing a sound install on her, and will keep you all posted. for now you can follow my initial ideas here: http://www.speedandsound.co.za/forum/vi ... 30&t=61141
Kingpin
What model / year is your Pajero? 2005 Gen3
How much mileage had your Pajero done? 236000km
Is it the original motor? Yes
Any major work? Unknown
Blessie
1996 Gen.2 3500 V6 282000 Km on clock.
Original Motor, Previous owner replaced clutch, fitted Iron man suspension. No knowledge of other repairs. I replaced front shocks with Gabriels, new valve lifters, cam belt & all pulleys, Chip & tune done by Dastek in Pretoria
Ravens
What model / year is your Pajero? 1999 Gen2 2.8 Tdi LWB F/Lift
How much mileage had your Pajero done? 272500km
Any major work?Not that I know off, :roll: Bought it a month ago but was searching for one for the last 8 months, a bit heavy on fuel but I will do a full service.
What model / year is your Pajero? 2000 Gen3 3,2Did GLS SWB
How much mileage had your Pajero done? 218000km
Any major work? No
Tyson
Great Idea, this is mine,
What model / year is your Pajero? 3.2 DiD 3 door 2003
How much mileage had your Pajero done? 316,000 kms
Is it the original motor? yes
Any major work? replaced one wheel bearing, timing chain and injector pump. ( injector pump recently replaced)
Does not use any oil from service to service.
Tyson
petem
Year and Model: 1996 3500 GLS
Mileage : 373 000
Work Done : Apart from regular maintenance - NIL until last months of her/his life - new clutch and then head cracked
Sold: R 15 0000 to someone who will do a few more kilometres with a new engine - miss her terribly !!
Grootvoet
What model / year is your Pajero? 1998 3.5 v6 lwb
How much mileage had your Pajero done? 250 000
Any major work? No, but sound like a tractor with the lifters making a noise :-)
What model / year is your Pajero? 2003 3.2 DiD SWB
How much mileage had your Pajero done? 204 500km
Any major work ? Diesel pump and injectors overhauled on 164 000km. As far as I know nothing else.
2003 Mitsubishi Pajero 3.2 DiD
1996 Toyota Land Cruiser 4.5 GX
Gregslenz
How much mileage had your Pajero done? 250 000km
Any major work ? Aircon compressor replaced under warranty 97000km. Diesel pump and injectors overhauled on 163 000km. Awsome vehicle with really efficient cost of ownership.
