Some more pics from the trail:)
Ok that means the 45mm spacers would lift the whole chasis including the diesel tank, gearbox all which look really low?Davidvan wrote:Hi Josef,
Gemaskerde Tuinvurk is right, the spacers on. The Pajero due to the fact it has independant suspension will mean it will increase the clearance under the Pajero as well, this is typically not possible with the solid axle 4x4 which would only raise the body.
David I'm really scared to take my paj again on such trails unless I get it lifted, add extra protection plates , good MTs, and I need to find out y I din't had any engine breaking on the slopes! U think it's only coz of the wrong tyre selection?Davidvan wrote:Hi Josewf,
The spacers are smaller, the resulting lift is 45mm and will raise as you queried. How often do you intend driving trails like this, you may need a few mods
Most of them had serious underbody damages, some had lost the front bumpers,one vehicle toppled on the slope.the slush part u see with the ribbon on side of the track was from day 2 speed competition event. I dint had to take part as I was broke down day 1 itself:)Davidvan wrote:
Looking at some of the pics, there would have been damage to other vehicles, they have been adapted to suit these conditions mostly.
I was not fast at all only crawling speed with 4LLC tiptronic on 1st and 2ndDavidvan wrote:
I have a few questions for you though:
What mode did you drive this route in?
Did you use auto or tiptronic?
What were your tyre pressures? (OK on HT's not much difference expected but every bit of traction helps)
What are you typical 4x4trails like, will these be common, if so some mods are really necessary
