PIRI D-ID
Paj 3.2 Diesel service
I just did the 215 000 service on my paj, i phoned Mitspro today and asked them about the oil presure switch, at the end of the conversation i asked them witch oil do they think is the best for the paj and he said delo 400 or castrol edge, when i told him i replaced with castrol gtx diesel he adviced me to drain the oil ASAP cause the gtx diesel oil is to thin for the engine :shock: is this acurate?
CTKB
Piri,
Yes, you got very good advice. Do drain the GTX as soon as possible. The GTX is formulated for petrol engines, that has much lower bearing loading values than diesel engines. Prolonged use in your vehicle will result in acellerated bearing wear.
The Delo 400 is the preferred oil of most heavy plant operators i know - earth moving companies, farmers etc.
Kobus
Re: Paj 3.2 Diesel service
CTKB wrote:Piri,
Note that he is refering to Castrol GTX Diesel, which is formulated for diesel engines.
CTKB
Oops, missed the diesel after the GTX. Still think the Delo 400 is a great oil ;-)
SWBstudent
You van also try engen diesel lube700 but its only avalible in 20l
