The pajero has a throttle flap that closes almost fully at idle (only at operating temp) and closes completely when shutting down the engine.
Reading a bit about EGR I suspect that the pajero uses PWM to partially close the throttle when EGR is activated to help draw in exhaust gasses.
With the EGR blanked less air/exhaust mixture enters the cylinders creating a rich mixture and possibly robbing some power.
I disconnected the vacuum diaphragms to test if it has more power this way at cruising speeds when the EGR will usually be activated.
See operation here - https://www.pajeroclub.co.za/forum/viewtopic.php?t=3035
It seems to feel more gutsy. But it would throw a CEL at idle (operating temp) as I suspect the Boost sensor picks up there is no vacuum.
So I T'd a vacuum hose from the idle diaphragm to the boost sensor (leaving the idle diaphragm disconnected, that will give the boost sensor a bit of vacuum at idle to fool it - it worked! No CEL at idle but the throttle flap is wide open.
I don't know if the engine kill diaphragm is the PWM (or if at all) so I simple just pulled the vacuum hose off that one (the downside is that I don't have an engine kill mechanism in case of engine runaway but I'll rewire that solenoid to get that functionality back.)
The car definitely feels like it has more oomph and time will tell if it helps my horrid fuel economy. I actually caught a fortuner D4D on the highway that was obviously gunning it by the looks of the exhaust fumes - whereas I struggled to catch a fortuner a few months ago - https://www.4x4community.co.za/forum/sh ... p?t=110922
I am still not sure if the Pajero's ECU uses PWM on of the throttle flap diaphragms for EGR but my mod has certainly given it some extra oomph.
