Yomomma
Dual Battery
Hi All, I have a 1997 Gen2 Pajero 3.0 V6. I already have a second battery installed that charges from the alternator. I want to install a 3rd battery to support the fridge. Would the alternator be able to handle all three batteries? Has anyone done this? Please guys, any comments or suggestions are welcome.
Site Admin
Re: Dual Battery
It might help to know what the second battery is used for before we can make comment on the 3rd. I don't think the alternator is up to cranking and 2 other heavy duty applications, but lets see...
Re: Dual Battery
I have 3 batteries in my 3.2Did and also a fourth one in the Xplorer. The alternator on the 3.2 Diesel is a bit bigger than the one in the petrol, I think, but even so, when all batteries all depleted the alternator alone struggles to get them back to full.
Maybe rather investigate solar power which is what I also have. This is the solution in the long run in my opinion.
Re: Dual Battery
I have the standard battery plus a 105Ah battery under the bonnet of my 3.2 DID. The 105Ah drives a National Luna fridge and this battery is charged via a National Luna split charging system. This system delays charging to the alternate battery for 5 minutes after startup, at which time the main battery almost completely regained its charge after having cranked the engine for the startup. So this works very well. Then in addition I tow a Echo Chobe which also has a 70Ah battery, but this one only drives the water pumping to the tap and a few light points. So it hardly ever runs flat. I have deliberately installed my fridge inside the car and not in the Chobe, so that I can use every opportunity to recharge the fridge battery when driving the car solo when I leave the camp for say sight seeing or game viewing. The full combination of 3 batteries works well and I have done at least 3 bundu trips with no 220 volt charger usage.
Ps. My car in 2004 was from one of only two shipments that came standard with 2 batteries. So the alternator is certainly fit for two batteries and I am sure that there is ample spare capacity for a light charge to a third battery. (In may case I upgraded the standard second battery to a large deep cycle one and installed the split charging system.)
Willie from Jo'burg
Yomomma
Re: Dual Battery
Thank you all for your advise. My second battery is a 105 ah battery that drives my Fridge (a 80l waeco fridge freezer). I have found that my battery run very flat after 12 to 16 hours of no driving, so I was thinking of adding a battery for extra help. It seems that the best battery to add is a 70ah deep cycle.
