Hi guys,
I have hid lights on my 2007 gls which I assume are self adjusting with sensors on the suspension. I would like to know how the lights can be adjusted manually. Had OME installed at mega and unless I've gone mad the lights look like the beams are not lighting up the road as far as they did before the lift?
Has anyone else needed to adjust the hids before?
Hi well just an update, I did eventually figure out which adjustment screws adjust the HIDs vertically and horizontally after a bit of searching.
There's a guy in OZ (Radar/John) who posted two documents in reply to a similar question in this thread:
http://www2.pajeroclub.com.au/forum/sho ... hp?t=10725
One doc for high beams and one for low beams. The two docs give detailed instructions on how to adjust the beams.
The one thing I had to find was a long screwdriver. Autozone sells a very (read 45 or 50cm) long phillips screwdriver, which worked a charm.
My headlights are now back to the level where they were before the lift...
