macjohnw
2005 Pajero Clock setting problems
The digital clock of the 2005 3.2D Pajero does not want to set. After pressing the "Adjust" tab, it does not want to select the "Clock" tab in order to set the time correctly.
Am I missing something here? Any other persons with the same problem?
FrikkievN
Re: 2005 Pajero Clock setting problems
Is die Pajero van jou n Auto ?
Ek het ondervind dat die voertuig moet still staan en in Park moet wees , voordat jy kan stel.
Ek het weer n ander probleem met die horlosie. Ek bly in die NW naby Rustenburg en as ek iewers heen ry veral as ek uit my area uit beweeg dan stel die ding hom self uit , so n uur en maar min wat hy hom self terug stel ! :oops:
ThePajeroMan
Macjohnw - Consult Manual or I will post update later today.
FrikkievN - In some overseas countries the clock works with the RDS system on the radio, and will automatically adjust the time accordingly. There is a setting on the radio that needs to be deactivated consult you owners manual or I will later today send you the settings.
I'm at the factory now and will only be back home later.
macjohnw
Thanks guys, I will go and have a look, will let you know.
ThePajeroMan
mackjohnw - This is probably what you have done but here goes anyway, on the GLS model at speeds less than 3km/h or standstill press the ADJ button then the CLOCK button, then press the SELECT button till you get to the time and adjust and press SET. Failing that - I have no idea.
FrikkievN - see if there is "CT" displayed on the screen
Turn Ignition to ACC
Turn off radio by pressing power/volume button
While pressing the CH4 button, press the power button until it beeps
The CT indicator on display will disappear
Hope this helps guys
bullfrog
Dankie manne...EK het 'n 2002 Auto en die tyd gaan ook heeltyd uit. My RDS is aan...Gaan dit verseker probeer. Dankie vir die inligting!!!
macjohnw
FrikkievN wrote:Hi
Dankie, dit was presies die probleem - die horlosie is nou gestel.
ThePajeroMan wrote: ↑Mon Mar 22, 2010 9:43 pm mackjohnw - This is probably what you have done but here goes anyway, on the GLS model at speeds less than 3km/h or standstill press the ADJ button then the CLOCK button, then press the SELECT button till you get to the time and adjust and press SET. Failing that - I have no idea.
I have the same problem and follow your sequence and yes it does switch the CT off, however when I switch the ignition off and leave a few minutes and switch on the CT is back. How do you save the setting to prevent this from happening... Thanks
