Update from mitsu!! They have checked everything from SCV, diesel pump,injectors, barometer pressure sensor and they all are ok. Now they are checking the intercooler....
Wht else could be wrong
car has been lying there for two months and the issue still not diagnosed
Very strange. Maybe the ecu itself?
Mitsu India is hopeless..the dealer say it takes two months for them to get the Ecu imported. Also they are not 100% sure it's the Ecu problem.
So I took delivery of the car today and gave it to another famous imported car garage here....
Still no hope. I was told today by a car expert that it could be a gearbox problem.
In park and neutral the car builds revs as it should but on drive it doesn't rev.
Sounds gearbox related to me as well. Have you tried to get any possible fault codes with an OBDII bluetooth device and a app like Torqtune on your smartphone?
Maybe that will give some pointers?
Thanks cats!! never knew about that. Will try it. So the pajero 4 is obd2 compliant? I'm using an iPhone 5. So is this should I be buying ? http://pages.ebay.com/link/?nav=item.vi ... ID=EBAY-US
Yes. In SA at least it seems that thr gen4 is OBDII compliant where the gen3 was not.Josef9177 wrote:Thanks cats!! never knew about that. Will try it. So the pajero 4 is obd2 compliant? I'm using an iPhone 5. So is this should I be buying ? http://pages.ebay.com/link/?nav=item.vi ... ID=EBAY-US
would check and update
