I own a 2015 Pajero Sport with the factory fitted radio.
I have been struggling to have a conversation on the hand free system.
My iPhone 6+ connects via Bluetooth without any problems but during calls the Bluetooth will connect and release repeatedly making conversations nearly impossible.
Mitsubishi SA solution is to reset passkey to 0000 this doesn't work.
The only solution is switch off the WiFi on the phone, this solves the problem
You will probably find that if you switch off the wifi, that solves the problem.....
Mitsubishi SA don't fix problems.
You just helped a few people all by yourself
Thanks !!!
Thanks !!!
My friend has the same issue on his Amarok.Vw have tried everything,cant get it right.So it seems a few cars suffer from this.I will tell him to see if he puts wi-fi off if it works
My 2015 PS works like a charm with my iPhone 6. Have you tried it in another vehicle? Is it not possibly a setting of some sort on the phone?
