Site Admin
Rim compatibility with trailer
I have bought a Wilderness 310 trailer.
The rims it comes with are 15" 6 hole 139.7 PCD. I believe this identical to the Gen2 Pajero
I'd like to replace the 3 rims on the trailer with the standard Pajero rims. And have the same tyres.
Is there anything I need to know? I believe I need different wheel nuts.
Re: Rim compatibility with trailer
Where will you source the Pajero rims?
I am sure they will work, as long as the off-sett is the same. Just maybe xheck weight ratings? But I am almost certain a loaded Pajero should be heavier than a Trailer, so it should not be a problem.
Site Admin
Roelf_le_Roux wrote:Where will you source the Pajero rims?
A friend is looking at changing his rims so I might get those.
I agree with Cats.
If you can get those rims, then do it. I'm sure any wheel nuts issues can be resolved.
