I would like to change the tail lights on my 2000 Gen 3, so the lights at the top can also work. Does anyone know where I can Buy Tail lights from that can have globes fitted or LED. Once I found lights I will take to an Autolec to wie it for me. Has anyone done this that can guide me.
Thank you kindly
Jaco Naude
Hi Jaco
I had the same situation on my 2005 Gen3. During a routine oil service at Mitspro in Centurion, Gauteng I mentioned it to the technician and he did it for me for R400, including the globes, globe fittings and everyting. Whereabouts are you located?
Hi Guys did it my self normal globes need some time to do it but it work very good and it looks good at night as well. I'm gonna change it with LED all you need is some background on wiring and you can do it your self.
Here is a write up of one way of doing it
https://www.pajeroclub.co.za/forum/view ... =27&t=2862
and here is another way
https://www.pajeroclub.co.za/forum/view ... 13&start=0
Guys,
You can also add a yellow bulb (light) to the reverse light part and thereby get an additional flicker light.
Cloyd
Cloyd
Just did my gen3. Purchased 2 round led lights from autozone includes brake, lights and inducators. Was a bit messy to install, cut open the black plastic on the tail light and glued it in place. THe wiring was easy because it's already available. Now I have brake , lights and indicator in the middle red placeholder on every side.
