What causes tires to run off unevenly? The blocks on the tire next to eachother are running off scew and unevenly - what is the story?
The tires only have 23,000km on.
I am having the alignment and shocks looked at tomorrow - I reckon it might be shocks when I come to think of it, it is not so stable around bends/curves.4ePajero wrote:
- alignment (toe-in / camber / caster)
- worn shocks
- worn ball joints / tie rod ends / Pitman Arm / idler arm
Hard to tell from the pics, but I have a suspicion it is "feathering" from extended high speed driving ...macjohnw wrote:What causes tires to run off unevenly? The blocks on the tire next to eachother are running off scew and unevenly - what is the story?
That looks like heal-and-toe wear. Although poor wheel alignment can aggravate this, it is something that is unavoidable on tyres of a more aggressive design with "knobbly" type tread blocks (such as the STs).
The root cause is that the tread block is bent over as tractive effort is applied in the contact patch, which increases the vertical load on the rear of the block and reduces it on the front. This leads to accelerated wear at the rear of each block, as in the picture.
The only cure is to cross rotate the tyres (at intervals of around 10000 km or less), which alternates the direction of rotation and equalises the heal-and-toe wear.
Gerrit Loubser
Gerrit, if I understand correctly this "tractive effort" occurs when you use 4wd? The reason being that this is on the front tyres only, the back ones are 100% ok.Gerrit Loubser wrote:That looks like heal-and-toe wear. Although poor wheel alignment can aggravate this, it is something that is unavoidable on tyres of a more aggressive design with "knobbly" type tread blocks (such as the STs).
The problem with this type of wear is that it is "self-perpetuating".
Once it starts, it gets progressively worse (the problem makes the problem worse, if you know what I mean
To rotate the tyre's direction of travel has two effexts:
When I was in the Army, we had this problem on the "knobbly" tyres fitted to eg Jeeps and Bedford troop carriers.
When it starts, it can ruin a tyre in one long trip on asphalt.
These wear patterns make the tyres very noisy as well (low frequency drone).
It seldom happens when the vehicle is used exclusively on loose surfaces, eg gravel.
- it starts a new cycle (the same pattern of wear, but in 'reverse'
- it increases the total rate of wear. Since less of the tread is in contact with the road (the high spots), they wear away faster than the rest of the tyre. (Catch-22)
The deformation of tread blocks happens on non-driven wheels as well, but it is more significant on driven wheels. Have the tyres with the heel-and-toe wear always been at the front or might they have been rotated from the rear to the front?
Gerrit Loubser
Yes it is exactly what happens - on rough rough asphalt it is quite as a mouse, but on smooth asphalt it really hums/drones. It feels like the nose is a bit boat'ish around corners, so I hope it is the shocks. Funny that the wear only occurs on the front wheels and not the back ones.4ePajero wrote:These wear patterns make the tyres very noisy as well (low frequency drone).
