I own a Gen1 paj.
I have a problem with the bushings on the idler arm (steerting), this bushings are defective and I need to reaplce them, until now I have not found it at all, in any shop. but they asked me if it is compatible with another generation. is it?? other wise I will have to make it my own but also found a problem, the lower nut located on the screw shaft it is so tight, I don't know it is is locked or I just need to use an extender to my wrench to use more force to release it. I am atttaching a pic of the idler arm and pointing at the nut.
thank you.
Israel
