I have installed heavy duty welding cable with 100A fuse and cole hersee switch from the main battery to the rear. This cable doesn't connect directly to the auxillary batteries but it provides power to the DC-DC charger (only when the cars ignition is on). Overkill to have welding cable powering the DC-DC charger - yes indeed! But electronics can and do fail when you least expect it. So should the DC-DC charger ever give up on me I can easily connect the welding cable to the batteries directly as an interim solution.
To date the system has worked flawlessly and I have never flattened the batteries completely even after 4 days of fridge & camping lights without charging.
Bruce
