Your understanding of things technical and your ability to articulate that understanding in writing is awesome.
Bruce
Absolutely! So we are all saying the same thing only with different emphasis here and there. I totally agree with your statement that the auto ecu will sort it all out. I tow in Drive and leave it all up to the ecu. (with minor exceptions such as down decents etc.) With the foot flat I find she changes down well before the driver even realises it is necessary.The ecu sorts everything out for you. Just don't use full throttle all the time and let the auto do its thing.
I agree with the comfortable statements. Every car has a range where you feel its comfortable. Just keep it there be it 5th, 4th, 3rd or whatever.
exactly how I drive without having anything to tow. I'm sure I'll do the same when towing.RoelfleRoux wrote:Cloyd,
Like 4ePikanini explained, allow the ECU to make that decision. As long as the selector is in D, the computer will not allow the engine to labour or allow the box to take too much torque on the 5th gear. Use the manual tip-tronic mode if engine braking is required down steep hills. If the road is very undulating and the box is constantly swapping cogs between 4th and 5th, then I would consider sticking it in 4th until the road flattens out again.
This is how I use my box, but I'm sure the clever guys here will correct me soon enough if I'm wrong.
Roelf
