MThompson wrote:
Hmmmm, I think is is 2xx/75/16. I also have an OME suspension lift. I will have to double check the size but I know its 16s not 17s.
Will check and get back to you on that.
[/quote]
Hi MThompson,
Will you please confirm yoru tyre size on the BFG KM2, I'm seriously considering them, and do so more each time I look at your pics
I've done a lot of reading, viewing and thinking. Never considered the BFG KM2, mainly due to price, but also though tread pattern was to rough. However, I struggle to read anything bad about them (apart from the general differences between between AT's and MT's. Apparently road holding on the better side for a mud terrain, possibly better performance in sand than BFG AT (don't see the same complains about debeading at low pressures as with BFG AT.)
All in all, a very confusing topic. Many angles and many good tyres out there.
Decided to go big and get muds. I'm willing to take the consequences.
So before I take the plunge, one last chance for input from you guys, these are my best quotes currently on 265/75/16 (Includes balancing, valves and fitting and VAT. Excl. alignment)
BFG KM2 - R3143 (still veeeerrry expensive in my mind
Cooper STT - R2400 (Yep, I believe HiQ / Tyremart brought them back)
Hankook Dynapro MT - R2475
Maxxis Bighorn 762 +- R2300
Maxxis Bighorn 764 +- R2400.
Always liked the look of the Coopers, but Gerhard's experience is a concern. The possibility of the tread pattern causing resonance with the Gen 3 bothers me. I'm willing to bear the noise of a MT, but not what he experienced.
MThompson and others with KM2, please comment on whether you're noise is coming "from outside the cabin" eg. windows or "through the undercarriage/ cabin".
Maxxis sounds good, 3 ply sidewalls - but concerned about availability should I need to replace a tyre. Same concern with the Coopers - although it sounds like they're here to stay.
Any input, especially your experience will be appreciated. Hoping to make a final decision soon.
