Page 2 of 2
Re: Gen ???
Posted: Tue Oct 30, 2012 1:18 pm
by Richard
Hi David
thanks for the mail and for the advise, i am in the process of looking for all you mentioned, and thank you for the name of a place that i can get the things from, they are scarce and very expensive if you can find them here.
humor we have enough fuel lucky cheaper than in SA bush and places to go enough.
thank you again for the help it is really appreciated
regards
Richard
Re: Gen ???
Posted: Tue Oct 30, 2012 3:18 pm
by andrew.ashton
Richard wrote:i have not yet had it on a serious off road trip but where i have been has been thick soft sand and have not yet had to select 4 wheel drive
Hi Richard, welcome to the forum and to mitsu ownership.
Please can I ask that you DO engage 4wd when off tar? Driving on gravel or sand without 4wd tends to cause more damage to the road / environment. You will also have better vehicle control and keep the drive seals etc. that are used only when in 4wd better lubricated and become aware of any problems before you need to rely on them. Also go play somewhere in low range occassionally for the same reason.
Enjoy!
Re: Gen ???
Posted: Tue Oct 30, 2012 6:28 pm
by Richard
Hi Andrew
thank you for your mail, and appreciate your comment, if i may ask not being funny in any way what effect can this have driving at very low speed in a reserve?
thanks again for your mail
Richard
Re: Gen ???
Posted: Wed Oct 31, 2012 6:26 am
Holy smokes that's a low price. Did you get it registered already? Many sell their imports cheap as they struggle with the legalities of getting it registered.
Sent via iPad & Forum Runner
Re: Gen ???
Posted: Wed Oct 31, 2012 6:36 am
by Richard
Hi 4e
yes rgestration in Botswana is no problem, i know that it is a problem in South Africa, you can't even take a import already registered in Botswana and register it in SA they won't even let you export the vehicle.
regards
Richard
Re: Gen ???
Posted: Wed Oct 31, 2012 8:21 am
by andrew.ashton
Richard wrote:Hi Andrew
Hi Richard, No offence meant or taken! If you look at your vehicle's footprint over sand in 2wd vs 4wd with centre diff locked you will see that there is a difference. In the latter case you will see a near perfect tyre tread imprint which represents almost no displacement of surface strata.
Re: Gen ???
Posted: Wed Oct 31, 2012 1:19 pm
by Richard
Hi Andrew
thank you i will try this and check the difference, thanks for the advise i take any advise and learn from it
have a good day
Richard
