Re: FUEL SPILLAGE
My sincere apologies.
Completely forgot. :oops: I'm going outside now. Give me a few minutes
Re: FUEL SPILLAGE
Sorry about that long waiting. I should have done this earlier. Hope this helps.
Blister
Re: FUEL SPILLAGE
Hi Marius!
Thanks for your photo
I am confused? :oops:
What are the other equipment around the non return valve?
I had the odd spill in the mean time and I did not fill up since we last spoke
Aslam
Non Return Valve Photo Comparison.pdf
(186.04 KiB) Downloaded 248 times
Re: FUEL SPILLAGE
It doesn't make a sound with the ignition and I can't hear anything with the engine running so I doubt it is a fuel pump. I can't remember or see any electrical connections either so the only thing I can think of is that it might be a charcoal canister of some sorts.
http://wiki.answers.com/Q/What_does_a_c ... _a_vehicle
What does a charcoal canister do on a vehicle?
It captures fuel vapors and prevents them from escaping to the atmosphere and then stores the fumes and recycles them to the fuel tank or engine intake for combustion as needed.
The long and short of it is that it helps to protect the environment and improve fuel economy.
Blister
Re: FUEL SPILLAGE
Hi Marius!
See what I found in the Repair Manual.
You think its the same thing? Unfortunately no sketches to confirm either way!
FUEL ACCUMULATORS AND DAMPERS
FUEL ACCUMULATOR AND DAMPER INSPECTION
Condition Code Procedure
Attaching hardware broken ................. A ... Require repair or replacement of hardware.
Attaching hardware missing ................ C .......... Require replacement of hardware.
Attaching hardware not functioning ............ A ... Require repair or replacement of hardware.
Connections leaking ..... A .. Require repair or replacement.
Inoperative ............. A ........ (1) Require replacement. Leaking ................. A ............
Require replacement. (1) - Inoperative includes intermittent operation or out of OEM specification
FUEL DELIVERY CHECK VALVES
FUEL DELIVERY CHECK VALVE INSPECTION
Leaking externally ...... A .. Require repair or replacement.
Missing ................. C ............ Require replacement.
Pressure leaking (bleeds down) .................. A .. Require repair or replacement.
(1) - Inoperative includes intermittent operation or out of OEM specification.
Any help from the greater Paj fraternity?
Aslam
