Re: Temp guage up and down
zeek wrote:
andrew.ashton wrote:
zeek wrote: Where would I be able to check coolant for exhaust gasses?
Silverton Radiators will do this for you. Takes about 5 minutes.
Thanks Andrew will go past there
Test done, left it for 10 minutes
Few all looks good. Happy days :-)
Exhaust gas check
Exhaust gas check
Riku
Echo 4 2011
andrew.ashton
4ePikanini wrote:That's great news!
+1
+2
Sent from my GT-P7100 using Tapatalk
Wow, so there is such a thing as good luck in this world. I'm really glad you received your share with this issue. Just another peek into the robust nature of those 3.2DiD motors.
RoelfleRoux wrote:Wow, so there is such a thing as good luck in this world. I'm really glad you received your share with this issue. Just another peek into the robust nature of those 3.2DiD motors.
Ha ha most definitely. Radiator hole opening in Vryburg, not on the highway. Nice people from Mahindra with radiator repair shop across the road :D Clamp failing 10km from home.
Our daughters carried us home and saved the engine ;)
Riku
Echo 4 2011
Nice one Riku! Also check the top pipe attachment on the radiator. Mine was plastic and started cracking, causing a intermittent leak. Silverton Roodepoort rebuilt it with metal and a good price
3200 Tdi GSL 2001 Written off
3500i A/T 5Dr 2001 Sold
3.2 Di-Dc GLS A/T 2008
Lock wrote:Nice one Riku! Also check the top pipe attachment on the radiator. Mine was plastic and started cracking, causing a intermittent leak. Silverton Roodepoort rebuilt it with metal and a good price
Ok cool thanks.
Nice people there both visits cost me nothing
Riku
Echo 4 2011
Riku,
If my eyes are correct, then I think the rubber seal between the radiator and body is missing on your Pajero. It is quite an important item as it prevents warm air from recirculating at slow speed under fan-cooling conditions. As easy as buying a strip of foam-rubber with glue on the one side.
Roelf
andrew.ashton
RoelfleRoux wrote:Riku,
Roelf
Well spotted Roelf!
Although, I think more correctly, it would read "the rubber seal between the AC condenser and the radiator.".
There should be a dense foam rubber seal that fits around all four edges between the AC condenser and radiator. It seems to just deteriorate to the point of disappearing.
Riku, it seems you are not far away from me. if you are passing by Northriding I will happily show you how I made a replacement seal with some rubber from Pro Auto Rubber and a bit of contact adhesive. PM me if you want to make a plan.
NNB never put any glue on the plastic header tank of the OEM radiators, it can lead to tank failure.
