Page 2 of 2
Re: Engine numbers of 4M41 engines
Posted: Sat Sep 05, 2015 7:39 am
by superairborne
CATS wrote:Have you checked for any possible fault codes on the setup as running currently?
Error code 41, throttle control valve. But the TCV has been swoped out and the wiring checked by an auto electrician without any change in the situation.
Posted: Sat Sep 05, 2015 3:19 pm
by Nick Gibson
Eish man. Seems you have ruled everything else out for now except the ecu. As far as I know the only bit controlled by the ecu is the injector pump, the rest are merely sensors and solenoids actuators...
If you have swapped the injector pump over from the previous motor and it is still doing the same, I don't know what else you can do.
I still reckon somewhere there is a loose or unconnected sensor causing the problem. TCV valve solenoid or map sensor.
Posted: Sat Sep 05, 2015 9:47 pm
I have read of code 41 previously in this thread.
https://www.pajeroclub.co.za/forum/view ... 3&start=10
Maybe related to some vacuum pipe not connected or broken as in that thread?
Posted: Sat Sep 05, 2015 9:56 pm
by superairborne
Done. Makes no difference!
Posted: Sun Sep 06, 2015 2:13 pm
by trekker1
I suggest a basic test that could have a bearing on your engine performance. Carry out a compression test, and compare with the spec for this engine, and your original engine.
Posted: Sun Sep 06, 2015 2:55 pm
by superairborne
trekker1 wrote:I suggest a basic test that could have a bearing on your engine performance. Carry out a compression test, and compare with the spec for this engine, and your original engine.
It were a compression issue the engine would smoke as oil would be combusted as well as diesel.
It must be an electronic/electric issue as from mid throttle on the engine does not even make an attempt to accelerate.
Posted: Sun Sep 06, 2015 4:36 pm
Electronic or vacuum on one of those many vacuum pipes all over the engine controling some or other function. Even a pin prick hole can lead to all sort of issues.
