Re: Calling all Suspension Experts
PierresPajero wrote: Sun May 22, 2022 6:49 pm @NatureFan does the sound persist even when you apply the brakes?
Hi there,
no, it doesn't. Maybe one more clunk and then it stops dead. And I can really only hear it when I am driving very slowly on a dirt (Uneven) road. A bad corrugated road is quite unbearable at the moment but the rattle is so bad that I can't tell if the clunking is playing a role (though I strongly suspect it is - my hearing is just not so good anymore :? ) PPS: I did have the rattle 'fix' done some years ago, but I think that has worn out now too....
At this stage, not the same clunk going over a speed bump or turning into a step-up drive way.
Do you have any ideas?
Hi There, Just wanted to know if you found a solution to this issue? It seem that I have the same issue as you describe it in your comment. would really appreciate a solution to this Issue.
Sorry, I had other woes for a while, and lost track of this thought. After the bushes, shocks and normal items that I replaced, the front bashplate (snow protector, standard issue) actually broke off from the front while I was driving on a dirt road. The noise and shock were quite exciting ;) . Since then I have had a steel bashplate fitted and I have had a fair share of drama with that too, as it expands on hot days and then it bashes against various body parts, depending on where you are driving. Luckily this particular issue was not related to any structural damage.
I hope yours is also relatively easy to repair.
