Re: Pajero Gen 3 suspension upgrade
Posted: Wed Jul 27, 2011 11:17 am
Hi, found this on a similar discussion on 4x4 community. Don't know if figures are accurate, hope it helps.
"How does this shock length compare to the OE ones?
Bennie, that is the $1,000,000 question. I have compiled the following information, mainly from the Aussie Pajero forum (http://www2.pajeroclub.com.au/forum/) and its (now defunct) predecessor:
Original shocks:
Front: Open 473mm, Closed 336mm, Stroke 137mm
Rear: Open 576mm, Closed 352mm, Stroke 224mm
Old Man Emu shocks:
Front (N1295): Open 472mm, Closed 327mm, Stroke 145mm
Rear (N152): Open 576mm, Closed 345mm, Stroke 231mm
Now here are Bennie's figures from Ironman:
Front: Open 470mm, Closed 350mm, Stroke 120mm
Rear: Open 575mm, Closed 350mm, Stroke 225mm
New figures from Ironman
Front: Open 470mm, Closed 325mm, Stroke 145mm
What I deduce from that lot is that:
Both at the front and in the back the OME shocks will limit the droop travel in exactly the same way as the factory shocks, because the open length is practically identical. Although they have a shorter closed length, the bump travel will be limited by the bump stop and the extra travel available will not be used.There is no way that OME shocks will enable greater total wheel travel than the originals. This is what Jur also found when he compared the OMEs with originals (He reported that earlier in this thread).
In the front the Ironman shocks have a slightly shorter open length and (rather alarmingly) a significantly longer closed length
(Bennie, I wonder if they made a typo). There is no way that they will increase wheel travel over the originals. In fact, one should make very sure that the shock does not become the bump stop >:D. Ironman seems to have provided the wrong figures originally. With the new numbers, the Ironman will still have a slightly shorter opne length and also a shorter closed length, so they will probably limit droop travel very slightly and have similar bump travel to the originals.
At the back, the Ironman shocks are practically identical to the originals, so travel will be the same.I am also pretty sure that the Bilstein shocks for the Pajero have the same open and closed lengths as the originals. I have heard a rumour that Monroe Australia (http://www.monroe.com.au/default.asp) has Gas Magnum TDT shocks (Front 16-0506+, Rear 16-0471+) for the Gen 3 that have a significantly longer stroke, but I don't have the open/closed lengths, so I don't know if the longer stroke would translate into an increase of wheel travel.
Koni also have manually adjustable shocks for the Gen 3 (82-2505 at the front and 82-2506 at the rear), but I am not sure what their specs are.
The only thing that is certain is that so far we don't know of any aftermarket shocks that will yield increased wheel travel over the originals.
Original shocks:
Old Man Emu shocks:
