Re: Cruise Control Disengages
Posted: Fri Feb 08, 2013 6:51 am
Thanks for the feedback
The Pajero Owners Club of South Africa Forum
http://www.pajeroclub.co.za/forum/
So do you put down the fix to having unplugged and replugged the static steering wheel column electrical loom connections?WillieLeeu wrote:See my previous post.
I have returned from Hartenbos and can confirm that my CC is now working fine, did only disengage once on steep mountainpas, with trailer and ran out of power. Therefore my problem was as loose or bad connection on the mutliplug behind the steering.
Willie
Let me give you feedback. After I unplugged and re-pluged it, it worked fine, with not once disengaging. However, after my recent Botswana trip on bad corrugated roads, it is again disengaging. I will inspect it again, and also check on that pin thing.RoelfleRoux wrote:So do you put down the fix to having unplugged and replugged the static steering wheel column electrical loom connections?
