Wildcoast
Re: 3.2 did burnt piston
peterpot wrote: ↑Tue Oct 16, 2018 9:11 am When I still had my Gen3 3.2, I wanted the injectors reconditioned and was told that they are very special and that in the whole of Gauteng only Allan Black in Springs is able to do so. So while it might be possible that another in Gauteng is now maybe able to recon them, I would question if anyone in your area might be able to do so correctly.
It appears that the same cylinder is effected every time. What does the piston look like? With very close inspection, you can identify / differentiate a piston that has overheated from a piston that has a faulty injector. I will be down there in E L over Christmas if it is available for inspection.
Rgds.
Hi Peterpot. My apology for the late response - I've not been on the forum for a couple of weeks.
My vehicle was scheduled to be worked on from today and I'm hoping to get some feedback this week once the head has been removed.
Thanks for the offer of inspecting the bits in December, but I'm hoping to have the vehicle all repaired by then.
Regards - Roger
