Gen 3 Headlight Wiring
Posted: Mon Jul 05, 2010 2:04 pm
by jaco_n
Can anyone tell me which cable is used for what in the headlight (bulb) connector. I see there are three. One should be normal light, other brights and the third ground? But which one is which?
thanks
Re: Gen 3 Headlight Wiring
Posted: Mon Jul 05, 2010 2:17 pm
it might be the same as the gen2 that uses negative switching. It is not the normal setup.
This is the relay wiring diagram to connect spotlights to a gen2
Posted: Mon Jul 05, 2010 2:32 pm
by jaco_n
thanks. So which wire activates the brights for the lamp?
