tonton
Owners Manual: Operation of Compass
Herewith the "cut-out" from the OM re Compass.
Pajero Compass.pdf
Owners Manual: Compass Operation
(736.46 KiB) Downloaded 601 times
Regards,
lester
Re: Owners Manual: Operation of Compass
Thank you Anton. This is exactly what I need. I took the pod apart today and realised that the indications I had was due to the wrong face panel fitted with no holes for the S button. The S button is depressed by the front panel when it is mounted. It must have been wrongly mounted when they were exporting the vehicle.
I drilled a 7mm hole where the S button will protrude and my screeen shows the S alternating from left to right!!! The only thing to do is to change out the light bulbs which have blown.
I think you have the manual I need. Let me know when you have finished loading it up. Thank you once again, Anton. Have a nice weekend.
tonton
WOW, looks like some ignorant technician mounted it in the factory! I guess some clusters do not include a compass - therefore the absence of the hole for the S - button.
Good to hear you got it sorted. You had my really rattled about the absence of the S - button.
I will keep you posted on the progress with making a soft copy of the manual.
Regards,
lester
I will include the pictures from the time it was mounted wrongly with the panel. Notice there is no S button.Image
This is with all the digits showing
Taking it apart
Addition of the hole for the S button
It's alive again!
