Cracked Transfer Case Cover
Posted: Mon Aug 02, 2010 1:57 pm
I recently bought a Pajero IO which leaked a little oil on the transfer case cover. I inspected it myself and though it was the galvanized washer between the filler plug and case. As far as my knowledge stretches this should be a copper washer, as it is more malleable creating a better seal.
After about 300km and 300 fights with the wife about the "small" oil stain on the driveway I decided to service the transfer case and replace the washer with a copper washer. I took it mechanic is Alberton that quickly pointed out that the transfer case was cracked on the filler plug hole.
The mechanic (only works weekends) said we had four options
- Try and "CROOK" it by using pratley steel and try to block the crack and leak. (1 week) (R500)
- Remove the cover and send it away for welding (2 weeks) (R2500)
- Try and source a used cover (2 weeks) (R2000 + ????)
- Source a new transfer case cover (8 weeks) (R2000 for the labour and R5500 for the cover from mitsh)
The mechanic seemed knowledgeable but I wasnt willing to be without transport for so long. So after a failed CROOK attempt by myself and Fielies, I took the car to Bosch in Alrode South.
I've been using this Bosch for almost 2 years and never had any trouble with them. They removed the cover sent it for welding, refitted it and serviced the entire drivetrain (inc seals) for R2300. Which I though was a bargain, and all this was done in less than a day.
The little pajero is now going strong (not leaking any oil) only problem is that it battles to float!!
