Blister
VHF & 29MHz TWO WAY RADIOS SETUP
Please advise/comment on my proposed existing Kenwood 7102 and new GME GX300 Two Way Radios fitment
Aslam
NEW PROPOSED TWO 2WAY RADIOS SETUP.doc
(297.5 KiB) Downloaded 294 times
Site Admin
Re: VHF & 29MHz TWO WAY RADIOS SETUP
That should work but will require some cutting.
Bear in mind the GME is not all that suited to flush mounting.. despite the sales blurb... the flush mount bracket will not fit in your proposed position.
I'm more interested in your antenna positions
Blister
Experience has taught me to have the aerials at the highest point thus it will be mounted on the uppermost position on the back side panel on both sides.
Blister wrote:Experience has taught me to have the aerials at the highest point thus it will be mounted on the uppermost position on the back side panel on both sides.
Whacko! You might also want to consider a roof-top mount quarter-wave antenna for the VHF radio, unless you have a roof carrier. Whatever, if you intend using both the current ORRA VHF frequencies, then replace the ZARA130 with a Zara60 antenna and trim it midway between the two ORRA frequencies, i.e. around 157.000 MHz. This will work more effectively than the Zara130 5/8 antenna due to the wide spread in the two frequencies.
-F_D
Blister
Hi F_D!
Thanks for the input. Must say that your jargon is a bit to technical for me but I will sure pass it onto to the techie
Aslam
