VHF & 29MHz TWO WAY RADIOS SETUP
Posted: Thu Aug 19, 2010 10:24 pm
Please advise/comment on my proposed existing Kenwood 7102 and new GME GX300 Two Way Radios fitment
Aslam
Aslam
The Pajero Owners Club of South Africa Forum
http://www.pajeroclub.co.za/forum/
Whacko! You might also want to consider a roof-top mount quarter-wave antenna for the VHF radio, unless you have a roof carrier. Whatever, if you intend using both the current ORRA VHF frequencies, then replace the ZARA130 with a Zara60 antenna and trim it midway between the two ORRA frequencies, i.e. around 157.000 MHz. This will work more effectively than the Zara130 5/8 antenna due to the wide spread in the two frequencies.Blister wrote:Experience has taught me to have the aerials at the highest point thus it will be mounted on the uppermost position on the back side panel on both sides.
