Derek27
MY10 PAJERO 4M41 DI-DC High Power Engine (GLX Model)
New Pajero 3.2 Di-d Motor now with 140Kw!!Amazing!
Derek27
Re: MY10 PAJERO 4M41 DI-DC High Power Engine (GLX Model)
Specs!!
NEW PAJERO 3.2 GLX LWB SPEC.pdf
(65.41 KiB) Downloaded 259 times
JDV
To all the 'knowledgable people' on the forum:
What part of the new engine(140 kw) can be used to enhance the power of the 'old' 3.2 DiD; or should it be a complete engine switch?
Cruiser
Engine swop -plus plus !! IMHO, or in other words nothing will be cheap to do -- it was a well thought out redesign not just a quick fix it seems !! -- or some plug and play and VOILA here are lots more power -- like some "people' want us to believe :twisted: :twisted:
The upgrade consists as follows:
Pajero 3.2l DI-DC lwb GLX
High Power Engine 140kw 441nm
Modified engine detail-Cylinder head (Intake port form has been changed)
Piston (Combustion chamber has been changed)
Modified Swirl control value (swirl ratio and port form has been changed)
Changed Turbo charger (large size turbo charger has been adopted)
Changed injector (improved combustion efficiency)
Pump impeller in the water pump has been upgraded
New Automatic transmission with new ratios
Rear aircon system standard (new)
Sat Nav System standard fiment from Planet Electronics
Skillie
A document Mitsubishi emailed me explaining al the changes in the 2010 edition Pajero.
Simon, if this is already on the forum, please delete this.
Regards,
New Pajero Engine Update.pdf
(3.13 MiB) Downloaded 591 times
