"The course content is structured to get you to the first repairer and a easy step by step guide to get your vehicle running again.
The course will be very hands on
Component identification
And what does that thingamajing do?
4x4 operation
Drive terrain
Electrical
Vehicle examination and pre trip inspection
Is there contamination of oil, wheel bearing shot? pipes ok?
Eish, its broken...AA on strike, what now?
Brakes
*brake pads
*repair brake lines/ blank off
*bleed brakes
Clutch
*slipping?
*Bleed hydraulics
Electrical
*atrernator bearings / belt /voltage regulator
*wiring repair
*spotlight wiring
*replacing fuses
*starter issues
Fan belts
*how to tension
*check for damage
*how to replace
Cooling
*overheating
*pipe repair and replacement
*Thermostat
*Radiator repair
Fuel system
*remove water
*replace filters
*Bleed diesel
*fuel tank repair
*fuel line blockages
Exhaust repair
*closing holes
Tyres
*debead
*repair
Oils
*check for contamination on diff and fill up
Steel
*how to weld using batteries, grind and prepare the job
*identify material
Suspension
*repair leaf spring
Fault finding
*car not starting, why?
Towing
*prepare broken vehicle for towing
*prepare damaged vehicle for driving
Emergency!
*You have rolled your car!!...WHAT NOW
*I finks my car is a submarine and goes for swimming lesson...How to revive a drowned vehicle?"
Of course, it would be 1st price if we can find a volunteer that's prepared to help us mechanically challenged Paj owners, failing that, contributions can be made
Please advise if anyone is willing and I am prepared to assist with arranging the day
Aslam
