After losing a wheelcap and hearing that new caps cost R800 each at the stealers and more than R100 at the scrap yards, I did a check on all the other caps, and found that some could be removed simply by pulling them off with one hand, while others require a fair amount of force and leverage.
ADVICE: Check them now and after every time they were removed, and bend out the clips to ensure a secure fit.
Else they'll fly when you hit a rough road, bump or water.
Thanks for that one now
lost one of mine last week going to kgalagadi
Van zijls pass Hah try van zyl's rus road
Henk Bannink
Eish!HBannink wrote:Thanks for that one nowlost one of mine last week going to kgalagadi
I suggest you put your name up at the scrapyards. And check their price in advance - otherwise they might find out what the stealers charge in the meantime!
Remember, the Colt used the same part. You'll probably also get one off a Colt, as there are many more Colts out there than Pajeros.
Check the clips on the other three in the meantime...
PS I have one more here, but it being in the Cape does make it difficult. I may be able to send it up with a colleague if you are interested, though.
I'm seeing henk in Jozi at Christmas. I can take it with me if Henk wants me to?
Henk, I'll swap it for a bashplate
OK by me. Henk, do you want to take the cap? I want R80 for it (you can pay when Simon delivers it).SimonB wrote:Anton
You cal always give it back if you think it is too "second-hand".
Regards,
Muito obrigado senhor, Danke shon, ngyabonga
Henk Bannink
YO!HBannink wrote:Muito obrigado senhor, Danke shon, ngyabonga
I recon that means "samblief, ek vat hom die wieldop"?
I will leave it with Simon.
Regards,
