What have you done to your Pajero today?
Last night I replaced the 82 degree thermostat with an 88 degree thermostat
adjusted the stops on the pitman and idler arm to save the CV's
cleaned and tested the coolant sensor and coolant temp gauge sensor
today I drove it to work :)
Last night I parked my Pajero in the garage and this morning it started and took me to work.
BUT..... BIG BUT.... If the couries service delivers on time, then I'll have a brand new Garman Nuvi 500 mounted somewhere in the Pajero before this day is out :D
Site Admin
Just bought a whopping great big 160 lpm compressor, and a new whip antenna.
The compressor is too big to mount anywhere but maybe I can get the antenna in this weekend
Just got my Pajero back yesterday after I fitted some rock sliders to it, as made by Org Knoetze from Tough stuff here in Gauteng. It also include hi lift jacking points, which I am very chuffed with.
If all goes well I will also soon be fitting the long range fuel tank that I bought second hand from Bennie, after he turned his Pajero upside down and moved to the dark side(ie bought Prado)
CATS wrote:Just got my Pajero back yesterday after I fitted some rock sliders to it, as made by Org Knoetze from Tough stuff here in Gauteng. It also include hi lift jacking points, which I am very chuffed with.
It did not happen, unless we see proof!
OK - As requested go here for my write up: https://www.pajeroclub.co.za/forum/view ... =31&t=1531
tonton
...and you had to go check at the far-end first, I would guess?
Allegro
Broke both 29mhz and UHF areals off mounted on the ARB bumper. Someone in my vicinity's remotes operates my garagedoor openers. Was about to drive into the garage when I noticed the door coming down. :shock: I did not have the garage remote with me and reversed out with a heluva speed. Fortunately the door only got hold of the x2 areals :|
Good thing it didn't shut down your pacemaker as well!
