Turning circle - Steering stops
Posted: Mon Oct 25, 2010 12:56 pm
I got this via PM so I thought I'd post as reference for future use
look at your suspension and find the following part that looks new in the pic - It's the pitman arm on the right side and on the left side you will have the idler arm that looks almost identical.
when you turn the wheel you will see that it moves from side to side. It gets stopped by a bolt on the inside. That bolt is the steering stop. screwing that bolt out will make the turning circle larger and vice versa.
In order to turn the bolt you first have to loosen the lock nut right against the chassis.
Yours will be turned out at different lengths and that explains the different turning circles for going left and right.
PS : I turned mine out deliberately to make the turning circle larger as tight turning circles shorten the life of CV joints and their boots.
regards
Marius
My answer as followsGood morning.
My name is ......... From the post(s) I gather that you pretty much hands on with the pajero.
If you can please advise . I have searched the forums for a answer as to the correct turning cirle for my 1998 Pajero swb eci multi v6 3000.
The car turns sharper to the left than to the right. The schematics show a very simple configuration. I had the wheel stops checked and set. When I last week had my front (top and lower) balljoints replaced I again asked the service centre to please attend to the problem but to no avail, the wheel alignent is spot on but not the turning to each side. The pitman arm is not bend, the tie rods look to be okay from what i can see. Firstly is it not nomal to expect/assume the car to turn equal amounts to the left and the right? Is there any specfications that one can use as a yardstick to check as to what extend the lh/rh wheel is adhering to the specified turning radius? I have now been told that they plan to reduce the turning to the left so it matches the rh side! which means you cannot get around the sharper cornes in one go? Any ideas
regards
Marius
