Gazzad
Need a new clutch fitted in Cape Town
Hi everyone
Can someone help with some advice. I have a 1995 2.5 tubo diesel and need a new clutch fitted. Can anyone let me know where I can go to have this done. I am in Cape Town.
Many thanks
Gary
Re: Need a new clutch fitted in Cape Town
Hi Gary
I also have a 2.5 Tdi, and I also had the clutch kit replaced, not too long ago (+-1500km ago).
The one important thing that I didn't know at the time, after I had the alternative kit fitted, I started to hear a "loose spring rattle" sound, when engine was idling. It dissapears as soon as clutch is pressed.
On enquiring about this slightly annoying noise, the w/s guys have told me it's because I should have fitted an ORIGINAL clutch plate.
They apparently don't give this noise problem, BUT....that the non-genuine clutch plate is OK to drive, as-is, and should give the SAME / SIMILAR lifespan service.... just a bit noisy. :? :?
I've put it through some rough testing, and have not picked up any adverse symptoms so far. :) :
Cost of alternative clutch kit is approx. R1750-R1850. Don't have a clue what the agents ask ????
Maybe it would be worth looking into buying a genuine clutch plate, and fitting alternative pressure plate & release bearing ?? ;)
Just an additional suggestion, have your clutch slave cylinder checked / serviced, while you do the clutch replacement, and have the clutch fork dust / mud boot's integrity checked, at the same time. Also the fly wheel spigot bearing, and g/box front oils seal. :) :
PM me if you would like some further news on hiccups / learning hurdles i've affronted, with our scarcer engine config...........UNLESS THERE ARE OTHER 2.5Tdi OWNER"S, WHO WOULD ALSO LIKE TO SHARE INFO ??? :geek:
Replacing a clutch assembly is not difficult.
Removing and re-fitting the transmission and transfer case is the schlepp!
When replacing the assembly, I firmly recommend (much of what Nino said):
  • remove the protection (bash) plates
  • take the vehicle for a proper chassis wash, making sure they clean around the transmission and engine
  • buy genuine Mitsu (the price difference is small)
  • replace all the components while you have the opportunity:
    • clutch plate
    • pressure plate
    • release bearing
    • spigot shaft bearing
    • rubber boots
    • transmission mountings (rubber), if necessary
  • borrow a clutch plate alignment (centering) tool from your local workshop, if there isn't one included in the clutch kit (see pics)
  • have the flywheel's face skimmed, whilst it is out
  • service the slave cylinder (or have it done)
  • service the master cylinder
Good reading can be found here.
Gazzad
Thanks Guys for the prompt good info.
I don't have the facility to do the job myself so need info on who I can take it to.
I went to the agents and they can't say if they have in stock or not as it is an Australian import. So I need someone to take it out and if I can't get a replacment will have to have it rebuilt, if that is possible.
I will replace as much as possible whilst out.
Thanks again
Gary
Do you have the VIN no?
Chassi No?
i will see whether I can find part nos on WINCAPS for you.
Hi.
If it's the same as my Botswana import, it's most likely the same as the Hyundai 2.5Tdi eng, & similar to the old Colts.
There is 95% chance that any general spares dealer WILL have the equivalent. I paid +-R1800-R1900, for the complete kit, at the begining of the year (just take your samples to them - Midas / Salt River, were able to help with mine).
JUST REMEMBER AS PREVIOUSLY ENTERED< MIGHT BE BETTER TO BUY THE GENUINE CLUTCH PLATE FROM THE AGENTS, they are sold as loose pieces, and the remainder at the general dealers. :)
Just first enquire with general dealers if they too, do sell items loose. :geek:
Gazzad
Thanks very much for your input.
I will get it taken out and take the sample to the agents first then if no joy to one of the others you mentioned. That is proberly the best way so not to get the wrong one.
Cheers Gary
tonton
Gazzad wrote:Hi everyone
Many thanks
Gary
Gary,
If you wish to have someone else do the job, try ANG or Mitsu Tygerberg, both recommended here: Pajero Workshop Recommendations
Do get quotes first!
From WINCAPS this is what I found:
CAPS LIST PRINT OUT 01.pdf
(16.18 KiB) Downloaded 220 times
CAPS LIST PRINT OUT 02.pdf
(88.33 KiB) Downloaded 205 times
