I recently bought a used 3.5 Gen 2 1997 GLS, the SAMCOR models with 280000km on the clock.
She is in a good condition and drives well.
Problem that i have is first cold start, she have difficulty to idle for about 10 seconds, then all of a sudden she idles normally. Also when she is cold she seems powerless.
Second problem is that if i accelerate from idle, there is a huge flat spot and hesitation before she responds.
I have already replaced spark plugs, repaired the butterflies, cleaned Airflow sensor and throttle body and stepper motor, but no luck.
The base CO2 is within spec and she does not have a co2 sensor.
Any ideas?
