I put the pajero in diagnostic mode to determine why the Super Select was acting up. I found the Super Select code. I also found a large number of ABS fault codes. The ABS warning light isn't on under normal conditions, so I'm not sure if I should worry about the reported error codes. The following were reported:
- 13 - Wheel speed sensor (RR) system (Open circuit or short-circuit)
- 14 - Wheel speed sensor (RL) system (Open circuit or short-circuit)
- 21 - Wheel speed sensor (FR) system
- 22 - Wheel speed sensor (FL) system
- 32 - G sensor system
- 52 - Value relay system (OFF problem)
There is another post here somewhere where the person found an error with the wiring to the ABS ECU. With so many different errors, perhaps thats what I have as well. Where should I start looking?
