Can someone please tell me where about is the oil filter situated on the 3.2 DiD Gen 3??
Looking back into engine compartment on your left hand side of engine. Easier to see sometimes from below, depending on bash plate fitted.superairborne wrote:Can someone please tell me where about is the oil filter situated on the 3.2 DiD Gen 3??
The setup looks almost identical to the diesel filter setup.macjohnw wrote:I heard 4e talk about a filter relocation kit - what does this entail?
Like this
i guess it will make it easier to get hold of the filter for changing it with a service but now you got more pipes to worry about that can burst and perish with time i think
__________________
Looks nice, thanks.4ePikanini wrote:The setup looks almost identical to the diesel filter setup.macjohnw wrote:I heard 4e talk about a filter relocation kit - what does this entail?
Like this
Marius some questions: In your opinion is it worth moving the oil filter and where would you move it to? If one were to move it up higher so as to access easier from inside the engine compartment rather than from the bottom, would the oil flow/ pressure be affected. Would it not be better to use Stainless pipes rather than the rubber pipes, or at least the braided pipes shown on the Diesel fuel kit?4ePikanini wrote:The setup looks almost identical to the diesel filter setup.macjohnw wrote:I heard 4e talk about a filter relocation kit - what does this entail?
Like this
From whom is the kit available?
Virgilio
From who is the kit available
Like this
Virgilio
It definitely helps for a cleaner service when changing the oil.virgilio wrote: Marius some questions: In your opinion is it worth moving the oil filter and where would you move it to? If one were to move it up higher so as to access easier from inside the engine compartment rather than from the bottom, would the oil flow/ pressure be affected. Would it not be better to use Stainless pipes rather than the rubber pipes, or at least the braided pipes shown on the Diesel fuel kit?
Virgilio
No, it doesn't affect the pressure.
Yes, I would use braided hose with the correct pressure rating.
Only kits I could find online was on ebay and they are not exact in their size specs so I won't go that route.
I would move it next to the diesel filter so I can spot leaks easily. And possibly pair it with this for extra cooling.
